It is currently Mon Aug 11, 2025 10:23 pm
 Post subject: bending cracked sides
PostPosted: Tue Apr 19, 2016 6:57 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I resawed some tulip wood yesterday for some ukes & the sides have some cracks in them and I'm wondering about gluing the cracks before I bend on the pipe, I guess with some kind of epoxy?
Anyone done this kind of thing?
MM
Mike McNerney
PostPosted: Tue Apr 19, 2016 7:08 am
First name: Tom
Last Name: West
State: Nova Scotia
Have not done Tulip wood but certainly repaired tight cracks in other woods before bending. CA is your friend for doing this type of thing.
Tom
PostPosted: Tue Apr 19, 2016 7:39 am
As Tom mentioned CA works OK for fine cracks, for sure in dark woods like Rosewood and Walnut. I think I'd pass on working Tulip wood that I know is defective -- I can understand salvaging Brazilian Rosewood.
Ken Cierp
PostPosted: Tue Apr 19, 2016 2:47 pm
agree with Ken start with good stuff .
PostPosted: Tue Apr 19, 2016 7:03 pm
"I think I'd pass on working Tulip wood that I know is defective -- I can understand salvaging Brazilian Rosewood."
Tulipwood - Dalbergia Frutescens ? It may not be BRW, but it's still a pretty nice wood.
Most epoxies don't take the heat too well. I would be inclined to use hide glue. Even if it failed part way through the bend, using bending straps you could probably finish bending and reglue without a lot of clean up. Good quality hide glue is almost colorless and may show less than some others.
PostPosted: Tue Apr 19, 2016 8:43 pm
City: winnipeg
State: manitoba
Country: canada
I have a similar problem with checked maple, except, I will bend it on a mold. What temperature should I stay below?
Bob :ugeek:
PostPosted: Wed Apr 20, 2016 9:49 am
I have some wenge sides that have cracked. I glued the cracks with fish glue. From whta others have said, I can expect some problems?
Under Compensated Nut!
PostPosted: Wed Apr 20, 2016 9:56 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
OK I see the common thread here but, I'm still going to try it. This piece of tulip is 40 years old.
I'll start with pva & if that doesn't work I'll try one of the JB weld products & reinforce on the inside.
I'll try to send some pics in a week.
Thanks all
Mike McNerney
PostPosted: Wed Apr 20, 2016 7:29 pm
Try titebond 2 or 3. They have worked well for me. Tulipwood not to be confused with poplar is a beautiful and expensive Dalbergia. I would definitely try it
PostPosted: Wed Apr 20, 2016 8:04 pm
I think titebond 3 might be the ticket for this setch...in general I hate the stuff, as it doesn't really harden until it is subjected to a temperature of around 200*...seeing as how you will be pushing it above that to bend it, it might be perfect for this issue...
PostPosted: Fri Apr 22, 2016 2:10 pm
Last Name: Beaver
City: Lake Forest
Titebond or CA, I would stay away from epoxy until after the bending is done. Most epoxies turn loose at 180-200 degrees. If that happens it would be a real mess.
Joe Beaver
Maker of Sawdust
PostPosted: Mon Apr 25, 2016 9:46 pm
City: winnipeg
State: manitoba
Country: canada
I have recommended thin CA left overnight but fish glue sounds recoverable the second time around. This side has yet to be thicknessed so staining will likely be reduced.
Titebond two and three are urethane glues so expect a thin yellow line.
Good luck.
Bob :ugeek:
PostPosted: Tue Apr 26, 2016 11:57 am
Pretty sure they are both PVA -- they do handle heat and water better than the Original formula
Ken Cierp
PostPosted: Tue Apr 26, 2016 2:26 pm
Last Name: Beaver
City: Lake Forest
I thought it was a Thin Red Line, oh wait, that was different
Joe Beaver
Maker of Sawdust
PostPosted: Tue Apr 26, 2016 6:21 pm
T3 dries dark...not yellow
